Home » Sponsored » Pi Speakers » JBL sub1500 corner horn?
Re: JBL sub1500 corner horn? [message #46089 is a reply to message #46088] Wed, 29 December 2004 14:12 Go to previous messageGo to previous message
That is a nice woofer. It works well in sealed cabinets, and is not underdamped (peaky) in even very small boxes, down to 0.5ft3. However, bass response isn't good unless the cabinet is made larger than at least 1.0ft3, where f3 is 60Hz. In my opinion, the speaker is best suited for vented cabinets between 1.0ft3 and 4.0ft3, tuned to 30Hz. Response extends almost a full octave deeper in this configuration, with f3 of 35Hz in a 2.5ft3 box tuned to 30Hz.
Just as a point of fact, I'd like to clarify something. There is absolutely no difference in the characteristics of a ported box and a sealed box that has equalization applied to extend response to match. If response is the same, then transient response and group delay are too. Please see the posts in the thread called "Resonance," which was an earlier discussion about this. A good T/S reference is the "Vented Speaker Systems" article written by Brian Davies. So you might consider these things when deciding on your implementation.
As for corner woofer placement, Dr. Floyd Toole describes the strengths and weaknesses nicely in his paper, "Loudspeakers and Rooms - Getting the Bass Right." The JBL1500 works very well in a seven π cornerhorn, slightly retuned for that woofer. The way this is done is to extend the vent on the Professional Seven π plans to fill the entire width of the cabinet. It's actually a simple mod that amounts to the removal of one side wall to gain a little bit of extra length, and it works very well. Those that have done it have been very pleased with its performance.
The π cornerhorn provides several benefits. For one thing, it increases efficiency. Another thing is that midrange and treble reflections are controlled because every sound source is horn-loaded, delivering energy into the room and away from the walls. Floor bounce and wall reflections are minimized and the directivity of all sound is equal.
Most speakers have omnidirectional bass and as frequency rises, it becomes more directional. There are often breaks where the pattern becomes more narrow as a driver becomes directional, and then at a crossover point, the pattern becomes wide again. This causes a non-uniform reverberent field and small "sweet spot." But seven π loudspeakers have uniform directivity and their sound is good everywhere in the room.
Previous Topic: Alpha 12 + Vifa DX25?
Next Topic: plans for seven and four PI
Current Time: Wed Oct 21 21:44:18 CDT 2026
