Home » Sponsored » Pi Speakers » horn types?
Re: horn types? [message #46046 is a reply to message #46044] Sun, 19 December 2004 22:15 Go to previous messageGo to previous message
scp53 is currently offline  scp53
ok, so what should i use for surround speaker HF drivers? no horn at all. a tweeter. i think ill wait on these and just build my center first.
for the center i think im going with a psd2002 or a SELENIUM D210TI 1" TITANIUM COMPRESSION DRIVER Part Number 264-235. which one do you think is better. this selenium caught my attention because it said movie theater use. where as other comp drivers are for strict pa use or so they say. so id use one of those comp drivers mounted on a horn with a 8 or 10 inch woofer. could you help me select a driver to match one those comp drivers? not sure how to match them. and the horn im not sure of either. this is for center channel use. i figure i can have a excellent center for less than $300 when its all finished. my only fear is it swamping my klipsch in every way. and this also brings up another Q. how do i match a 105-107 db driver to a woofer with only 90-95?
thanks a lot
scp53
Previous Topic: Piezo info
Next Topic: Virginia Beach Area Pi Speaker owners?
Current Time: Mon Oct 26 07:36:02 CDT 2026
