Home » Sponsored » Pi Speakers » Here's some JBL Horn news
Re: Here's some JBL Horn news [message #45983 is a reply to message #45922] Thu, 09 December 2004 12:17 Go to previous message
spkrman57
Bill,
The JBL drivers out of the 3677 cabs are designed for minimum crossover of 1.2khz but will probably squeak by due to the horn loadeing of the 811B which is actually a 550hz flare rate.
I think muse is turning into a real audio critic. Does she tell you which horns and drivers to use????
Are you still running the 15 ohm resistors on the speakers for the 8 ohm load to the amp. It would probably be sweet if the "Ella" had 16 ohms taps to run your speakers without the parallel resistor to tailor the impedance to the amp.
Ron
Previous Topic: Lightweight One Pi
Next Topic: importing speakers into australia
Current Time: Wed Oct 21 05:06:06 CDT 2026
