Home » Sponsored » Pi Speakers » Studio 2's and Subwoofer
Re: Studio 2's and Subwoofer [message #45924 is a reply to message #45919] Tue, 30 November 2004 10:54 Go to previous message
Crossover between 60Hz and 100Hz. If you're planning to go with just one sub, I'd go with a high-order slope and use an amp that allows some adjustments. When you use a single sub, it is usually pretty far away from the mains so you'll want to have some ability to tailor it according to placement and room conditions. If you can go with two subs, I'd place them within a couple feet of your two π's and I'd use a first-order crossover. In that way, the transition will be seamless because with sound sources are within a 1/4 wavelength of each other.
Previous Topic: Wondering about the diff between $60 Alpha and $230 JBL in 8Pi?
Next Topic: FYI: Used JBL horns/drivers for sale
Current Time: Fri Nov 06 07:52:56 CST 2026
