Home » Sponsored » Pi Speakers » Sex amp and the Pi speakers
Re: Sex amp and the Pi speakers [message #45858 is a reply to message #45855] Mon, 22 November 2004 23:28 Go to previous messageGo to previous message
Theater 4's work best against walls. They're horns, and being more directional than direct radiators makes the placement rules a little different. Best placement is on the floor and against a wall. If placed in a corner, angle it in so that the horn isn't pointed where you'll get reflections off the side wall.
If you put the speakers in a corner and angle them in 45o, the corner of the room makes the bass dispersion pattern equal the treble dispersion. You won't have side wall reflections because the tweeter flare pattern is within the wall angles. That's a very good placement option for 90o horns.
Previous Topic: Thermo Pi 3 as kit ?
Next Topic: Cap Rating for XO?
Current Time: Wed Oct 21 03:33:40 CDT 2026
