Home » Sponsored » Pi Speakers » Mounting H290 flare ( with driver attached) to front baffle.
Re: Mounting H290 flare ( with driver attached) to front baffle. [message #45852 is a reply to message #45850] Mon, 22 November 2004 11:08 Go to previous messageGo to previous message
No. 10 bolts and T-nuts will work. For attaching the horn on the front baffle, the bottom screws do all the work.
If you want a big challenge, you can flush mount the horns into the baffle.
Gar.
Previous Topic: Hi wayne any new development on the 12 pi sub horn?
Next Topic: Thermo Pi 3 as kit ?
Current Time: Wed Oct 21 01:23:55 CDT 2026
