Home » Sponsored » Pi Speakers » Loudspeaker Venting and Cooling Techniques
Re: Loudspeaker Venting and Cooling Techniques [message #45807 is a reply to message #45802] Wed, 17 November 2004 14:54 Go to previous messageGo to previous message
Sounds great, Wayne. I would have only two concerns though. First, I would be worried that a one-way valve would introduce a great deal of non-linearity in cone movement. On the backstroke (or frontstroke, depending on the valve positioning), the cone movement would have relatively little air resistance due to the open vent. On the opposite stroke, however, it would encounter more pressure. It would actually be even worse than a conventional, non-vented pole piece, as the cavity in the voice coil would draw in extra air (or push out extra air), and create either a very high pressure or very low pressure region, which could fight cone motion. Seems like a recipe for distortion.
Also, venting the pole piece to the outside to me would cause cancellation. The back of the dustcap creates it's own pressure waves, which could cancel out regular enclosure output.
Thoughts?
Adam
Previous Topic: Some Questions Regarding This PA Subwoofer
Next Topic: 12π and 15π horn loudspeakers
Current Time: Sun Nov 22 20:07:09 CST 2026
