Home » Sponsored » Pi Speakers » Conical horn for 15" driver
Re: hornresp question [message #45767 is a reply to message #45766] Mon, 08 November 2004 16:12 Go to previous messageGo to previous message
VTC is the volume of the front chamber and ATC is the average cross-section of the front chamber. Set VTC to the volume of the cone and ATC can be probably a little less than SD. The shape of the front chamber is a cone, so cross-section area is tapered. You can vary these parameters a little bit and they don't do much to response. For example, the additional volume made when the driver is offset from the baffle with a gasket or thin spacer won't make a measureable different. But if you double the front chamber volume, that will.
Previous Topic: bi=amp studio 2's
Next Topic: Question for Wayne
Current Time: Sun Nov 29 03:31:58 CST 2026
