Wayne Parham Messages: 19108 Registered: January 2001
We're thinking along the same lines here. The size of the horn will depend on your intended useage. If you plan on using them in the house, your horn can be made much smaller than if you need to be able to use them flown in freespace.
In freespace, you'd need dimensions of about 4 feet, both in length and in height and width. But in home, you could downsize this and still expect good results. This kind of horn is real easy to model with Hornresp.
