Home » Sponsored » Pi Speakers » Four Pi questions
Four Pi answers [message #45721 is a reply to message #45719] Tue, 02 November 2004 15:15 Go to previous message
The Stage, Premium and Professional Series cabinets are all the same. Since a woofer and cabinet should be matched, this is not always possible. In fact, it is rare that you can swap woofers in cabinets and stil retain an optimal match. However, there is a certain about of goal setting evident in the designs of each of the woofers used in these cabinets - Many manufacturers produce 15" woofers designed to work well in cabinets from 2.5ft3 to 5.0ft3 tuned to 40Hz.
Crossovers are slightly different, but quite easy to configure. You'll find a chart that shows the components required for each model in the plans.
As for your amps, your 50 watt McIntosh amp will work well with any of them. For that matter, so will your ASL 8 watt amp. I have used each of these with the 2.5 watt Bottlehead Paramour and the 9 watt Stoetkit Ultralinear amp and both sounded great.
Previous Topic: Kilomax power
Next Topic: Anyone into guitar, 4X12 cab. plans needed.
Current Time: Fri Nov 27 07:42:10 CST 2026
