Home » Sponsored » Pi Speakers » Xover choices and my issues(long)
Xover choices and my issues(long) [message #45687] Mon, 25 October 2004 20:41 Go to previous message
Hi all
This post consists of the backround info ,a Question about my future system,and a thanks at the end.
Story
After going to the FRD consortium I read the Phase files and downloaded the programs. I became convinced that absolute phase was necessary since
1) "Square waves are a good test of a speakers time linearity"
2) "A speaker that can pass a square wave well sounds better"
3) Pv consultants are 'experts' so i should beleive them!
4) Even a couple on AA agreed with square wave testing.
It pretty much made sense - Although Kreskov failed to tell us - or measure exactly how much better his 'Magic speakers' are with all the phase linearity they have!
Then after reading Rod Elliots and Waynes files on phase
I was told that
1) Square wave testing doesnt actualy matter
2) You can get a good square wave response by moving the measurement mic around the room
3) Absolute phase isnt audible but relative phase is
And Rod Elliot seems like another down to earth physics and truth guy!
Conclusion
Its nice to have some fact around here! I was getting (even more!) worried about my next 3.1 way horn system and how to filter it !!
-Active Filtering
-Id prefer high order linkwitz riley filters
Question
In the PI crossover document the issues of passive crossovers and resonance between reactive components are explained and dealth with.
Using active filters i wont have to worry about MOST of that.
-Can my Active Filter circuit simply be chosen by Order and Fc and thats it?
Im not after Audiophile sound
-After all the music i listen to is Made in a studio with synths and computers and is only heard live at venues on systems that sound worse than mine
Also considering Directivity,Horn Types etc.(if i can figure out a 70hz-300hz midbass horn i can fit il be doing that rather than 12"/15" direct radiator!
Thanks to wayne for putting the time and effort into educating and helping people around here!
Now,where did i see that version of spice with a nice GUI!
Regards,
Mike.e
Previous Topic: Wayne: Showroom in Tulsa post
Next Topic: Great Plains Novemeber Community Meeting
Current Time: Tue Nov 03 05:04:17 CST 2026
