Home » Sponsored » Pi Speakers » Questions, questions
Thanks [message #45654 is a reply to message #45651] Thu, 21 October 2004 12:23 Go to previous messageGo to previous message
dwk is currently offline  dwk
Thanks, Wayne. I've only had time for a glance at the plans - lots to digest.
Seeing the plans, things are simpler than I thought - basically a box firing into a corner, with some outrigging. The compound miter cuts on the mid horn are probably the toughest part.
Have you had a chance to A/B the Deltalite vs the ceramic equivalent? Since weight isn't a concern here, is there a sonic advantage to the neo? In theory, it might have slightly lower distortion, but I'd guess you'd be hard pressed to tell any difference at typical home levels.
Previous Topic: active crossover
Next Topic: 4Pi and 7Pi plans
Current Time: Mon Nov 02 10:54:25 CST 2026
