Home » Sponsored » Pi Speakers » Mid horn question
Re: You've got mail! [message #45629 is a reply to message #45622] Mon, 18 October 2004 20:00 Go to previous messageGo to previous message
Thanks for the files Wayne. From the looks of it, the woofer and mid are attenuated on the high end with a psuedo 1st order, but there's nothing on the low end of the mid. Does the horn itself act as the high pass filter or is the system designed for the mid and woofer to blend together under 250Hz? I'd also imagine that the woofer overlaps with the mid up to 1KHz too, unless the corner horn acts as low pass filter.
Previous Topic: active crossover
Next Topic: Pi10 plans
Current Time: Mon Oct 12 16:12:01 CDT 2026
