Home » Sponsored » Pi Speakers » Mid horn question
Mid horn question [message #45589] Sat, 16 October 2004 10:47 Go to previous message
I received my 2123H drivers this morning. They are OEM units still in their original boxes and haven't ever been installed yet, still have their final test tags on. Anyway now I need your midhorn kit, and after looking at all the diagrams on your site & forum, it appears that I must build a small enclosure to go on the back of the unit, correct? If so, what size should it be for this particular driver? About the only discussion I have seen about this said something like "anything over a 1/2 cubic foot" The JBL info says from 1/4 to 1/2 cu ft, so I guess that sounds about right? Is there any tuning advantage to the box size on the rear? What sort of stuffing and amount, if any, should this chamber be filled with, All this is probably in the instructions that come with the mid horn kit and I should just shut up and order it?
Thanks in advance,
Russystems
Previous Topic: active crossover
Next Topic: Pi10 plans
Current Time: Mon Nov 02 09:38:34 CST 2026
