Home » Sponsored » Pi Speakers » 2 pi questions:
Bracing [message #45524 is a reply to message #45523] Wed, 06 October 2004 00:07 Go to previous message
tube_ee is currently offline  tube_ee
I've got enough room in my cutting plan for one more piece the size of the top and bottom panels, so there's one "window" brace. If I go with the one brace every 18" that you've recommended elsewhere, I get one brace, about halfway between the woofer and the bottom of the speaker.
If I use one 15"x13" brace with 4"x3" cutouts, and run 1/2" x 1/2" vertical strips up each corner, with 2 horizontal strips per panel, I get a volume about 5 ft^3 less than what I calculate for an unbraced cabinet built with 5/8" stock. What effect will this difference have on the woofer alignment? Would this be sufficient bracing to compensate for the thinner walls?
For additional vibration-killing, what about gluing some asphalt roofing tiles to the insides of the panels? It shouldn't affect the volume much. Or you could use a marble plinth and thinner marble top, "sandwiching" the speaker between them, or...
The mind runs amok.
Tanks for all the help,
--Shannon
Previous Topic: Wayne
Next Topic: 'phile 7 plans plz
Current Time: Tue Sep 29 18:55:50 CDT 2026
