Home » Sponsored » Pi Speakers » Re:harshness & sibliance
Re: All movies? [message #45420 is a reply to message #45416] Thu, 23 September 2004 08:56 Go to previous messageGo to previous message
James,
I asked because most audio content in movies are processed and synthesised more than the meat you find in baloney. In some movies, the audio track is completed stripped from the footage and recreated in computers. And you know what happens when you have poor content and revealing speakers...
But from the sounds of it, the problem is consistent across all movies. I'd probably check your connections and soldering inside the speakers. A month ago, I had a poor connection with the horn tweeter. Low frequency pressure from the woofer caused the connection to vibrate which in turn introduced a buzz in the HF.
Gar.
Previous Topic: Anyone use a diferent tweeter for the studio 2?
Next Topic: Pi 2 question
Current Time: Sun Nov 29 00:34:02 CST 2026
