Home » Sponsored » Pi Speakers » mid horn
mid horn [message #45392] Mon, 20 September 2004 05:07 Go to previous message
Zeno is currently offline  Zeno
Hi wayne,
Thanks for the Pi 8 & mid horn plan you sent, is the mid horn design to cut of at 150 low freq(hz)
let say if I would do a 12-sided tractrix front horn what is the cut off fre I should go for ? you mentioned in one of your post that the vocal for male are especially good at around 130, do you think I can try cutting off at 100?
Thanks
Zeno gabriel
Previous Topic: Questions on some mid horn alternatives...
Next Topic: Question for PI Corner Horn Owners
Current Time: Sun Nov 01 11:25:10 CST 2026
