Home » Sponsored » Pi Speakers » Questions on some mid horn alternatives...
Re: Questions on some mid horn alternatives... [message #45388 is a reply to message #45385] Sun, 19 September 2004 14:17 Go to previous messageGo to previous message
Sounds like a great idea. Adrian Mack did something like this, making a smaller horn for a 6" driver. I think he used the Eminence Alpha 6, but there are no doubt other suitable drivers. Fostex seems a likely high quality canidate.
Personally, my goal was to have a midrange horn that could crossover very low, so to cover the entire midrange band. The note C below middle C is 130Hz, so you can easily see that male voice has a lot energy in this range. Wavelengths are long at this frequency too, so spacing and overlap are not nearly as critical. I felt I could use a larger horn and crossover lower with a shallow first-order slope for a seamless transistion down low and keep all the vocals and midrange in one driver.
With a 1.6kHz upper crossover frequency, I didn't really need to reach very high with the midrange horn. That's where I spent most of my time, working on the aspects of the subsystem at this frequency. I am pleased with the transistion between mid and tweeter horns, truly the most critical part.
But anyway, I think it would also make sense to use a smaller midrange and push the crossover points up an octave or so. You could probably get a smaller 6" driver to go up to 3kHz, and maybe even further with a phase plug. That would then allow other choices for tweeters, so the idea certainly has merit in my opinion.
Previous Topic: Stage 4 Pi ramps
Next Topic: mid horn
Current Time: Sun Nov 01 12:42:15 CST 2026
