Home » Sponsored » Pi Speakers » 4 PI Pro and horn flares
4 PI Pro and horn flares [message #45358] Sun, 12 September 2004 13:28 Go to previous message
Wayne,
I am finally getting semi serious about assembly. I have the jbl drivers necessary for the 4 PI Pro ( 2225H and 2425H w/ 2370A flares) but looking at the dimensions I have realized that the 2370A does not fit the hole prescribed in the plans, and I really don't want them setting on top like my A-7 Altecs. So I ordered a pair of the eminence ( H290 I believe ) flares. Will these fit the jbl drivers I have? They are the type with screw on mounts, but I also have adapters that screw on and adapt them to either 2 or 3 bolt pattern. Hope I didn't jump the gun and order the wrong thing for my application. I asssumed that it would work, since the kit you sell does not specify a different flare if you order the JBL 2426 H option.
Thanks,
Cody
Previous Topic: Pi 8 & mid horn
Next Topic: Pi Gallery location has changed
Current Time: Tue Nov 03 21:16:28 CST 2026
