Home » Sponsored » Pi Speakers » Anyone use a diferent tweeter for the studio 2?
Re: Thanks! [message #45352 is a reply to message #45345] Thu, 09 September 2004 16:37 Go to previous messageGo to previous message
Thanks, I have not tried this with a SET. Maybe I can hook up my 300B to them someday. If I was going to guess. They should be fine. The original efficiency is maintained and the attenuation is just a preferance. The tube amps usually have problems with woofer impeadance and that should not be a problem in this case. The Box size, tuning and woofer has all been worked out by Wayne and I wouldn't deviate from that. No reason this couldnt work with the 2 Pi tower, it's a larger box with deeper response. For a size inbetween you would have to consult with Wayne.
Previous Topic: Crossovers
Next Topic: Re:harshness & sibliance
Current Time: Wed Oct 21 06:17:43 CDT 2026
