Home » Sponsored » Pi Speakers » Heresy components and pi speakers ?
Re: Heresy components and pi speakers ? [message #45325 is a reply to message #45321] Tue, 07 September 2004 10:52 Go to previous messageGo to previous message
It looks like you've gotten some good responses already. The only thing I'd like to add is to suggest a π cornerhorn as a possibility. It is a simple cabinet to build and I think it sounds great. So if you have two good corners, this might be an attractive option for you.
seven π cornerhorn
Get the best woofer you can afford and implement it in a π cornerhorn. Since the Klipsch midrange and tweeter were baffle mounted, I expect the crossover is already worked out to sum properly and I also assume the midrange crossover frequency is pretty low. So just crossover the woofer in the π cornerhorn at that point and add a conjugate Zobel and it would work very well.
Previous Topic: Transcendent SE OTL and Pi Thermionic 3's
Next Topic: ideal enclosure volume for alpha 10
Current Time: Fri Nov 13 08:17:19 CST 2026
