Home » Sponsored » Pi Speakers » woofers for sub horn
Re: woofers for sub horn [message #45238 is a reply to message #45236] Fri, 20 August 2004 18:21 Go to previous messageGo to previous message
I'm primarily concerned about output below 80 Hz, so that shouldn't be a problem. Woudl you be able to help me design a 25-28 Hz, 1/8th space, 1/4 wavelength exponential horn for this driver? The only limitations is the horn can't occupy more than 12' of width and the mouth can't be taller than about 8'. There will be a stereo pair of the horns built into a wall, with the mouths of the horns emptying into the corners of the room. Also, will this subwoofer be commercially available after the preorder?
Thanks Wayne!
Adam
Previous Topic: evil woofer
Next Topic: Is Pi for me
Current Time: Mon Nov 02 06:23:28 CST 2026
