Home » Sponsored » Pi Speakers » Theater 4 Pi Questions
Bracing [message #45165 is a reply to message #45162] Thu, 05 August 2004 12:33 Go to previous messageGo to previous message
Frank,
My method is not Wayne-approved, but I'm a big fan of "window frame" bracing. It ties all four sides together and, if you are using a table saw, it's easy to get the dimensions right becauses the frames are the same size as the top and bottom. Just cut the braces at the same time and with the same fence settings as the top and bottom. (If you're not going to be using a table saw, then I'd go with Wayne's method.)
The bracing I used for my Pi Studio 2 Towers is illustrated at the attached link.
Previous Topic: Pi sevens in a big room
Next Topic: thank you wayne
Current Time: Fri Oct 23 05:12:37 CDT 2026
