Home » Sponsored » Pi Speakers » re size the opening of the mid horn
Re: re size the opening of the mid horn [message #45079 is a reply to message #45075] Tue, 27 July 2004 04:45 Go to previous message
If you want a axisymmetric horn, that would be fine. I like the 90o dispersion because it works so well in the home, particularly in a cornerhorn. But if you want axisymmetric, you can certainly go with a different dimension. If they will be used in free space, you may want to make them larger.
Previous Topic: alpha 10
Next Topic: marble again
Current Time: Mon Nov 02 02:46:07 CST 2026
