Home » Sponsored » Pi Speakers » Crap bought a bunch of worthless crossover parts
Re: Crap bought a bunch of worthless crossover parts [message #44987 is a reply to message #44983] Sat, 17 July 2004 02:46 Go to previous messageGo to previous message
You can use (8) 8 ohm resistors to form a high-power 8 ohm block. Connect two in series and four banks of those in parallel. Use the remaining two 8 ohm resistors for something else.
For the 12dB cable assembies, you need a 25 ohm resistor and a 16 ohm resistor. The 10dB assembly needs two 16 ohm resistors. Use all non-inductive 10 watt parts, and build them up in blocks of four. So each really uses a "resistor block" made using four 10 watt resistors.
For the 25 ohm resistor used in the 12dB assembly, we use two pairs of series connected resistors, one a 20 ohm and the other a 30. The series connection gives 50 ohms and two of those in parallel makes 25 ohms.
The 16 ohm block is easier, since it uses four of the same part, a 16 ohm resistor. Two in series, and the 32 ohms that is formed is then connected in parallel to another just like it to make 16 ohms.
There are photos of the cable assemblies here.
Previous Topic: Theater 4pi Plans
Next Topic: What is the bolt size and length for mounting the PSD-2002 to the H-290?
Current Time: Tue Oct 20 21:28:23 CDT 2026
