Home » Sponsored » Pi Speakers » Crap bought a bunch of worthless crossover parts
The resistors that you do have... [message #44985 is a reply to message #44984] Fri, 16 July 2004 21:49 Go to previous messageGo to previous message
the 25's, the 16's and the 8's - what are their dissipation ratings?
If the 8 ohm resistors are 20W, then two 8's in series will give you 16 ohms at 40W.
If you need 25 ohms, use three 8 ohm resistors in series for a total dissipation of 60W at 24 (close enough to 25) ohms. Power resistors are like what, + or - 10% ? So three 8 ohm resistors will give you something like 21.6 to 26.4 ohms, depending on how the tolerances stack up?
What's going to get kind of silly is making an 8 ohm, 100 watt part. You're going to have to series/parallel so may individual pieces it just won't be practical.
Previous Topic: Theater 4pi Plans
Next Topic: What is the bolt size and length for mounting the PSD-2002 to the H-290?
Current Time: Wed Oct 21 00:52:07 CDT 2026
