Home » Sponsored » Pi Speakers » more altec pi issues
Re: more altec pi issues [message #44971 is a reply to message #44969] Fri, 16 July 2004 16:07 Go to previous messageGo to previous message
Tightwad is currently offline  Tightwad
I recently used threaded inserts on a turntable project (see photos). Basically, figure out what size screw/bolt you want, then get the size of threaded insert to match the screw. Test on a piece of scrap first, make sure you're drilling the right sized hole. Again, the hardware store ought to have them. The detail photo shows one of them, albeit blurry.
Loctite is a liquid that dries to rubber-like consistency, whenever you have metal-to-metal contact it helps prevent loosening due to vibration. The medium-strength stuff unscrews pretty easily, it's not permanent.
Best of luck with your project. I'll bet it will sound fantastic.
Previous Topic: pialign.exe and XP
Next Topic: Theater 4pi Plans
Current Time: Sat Oct 17 06:14:45 CDT 2026
