Home » Sponsored » Pi Speakers » more altec pi issues
Re: more altec pi issues [message #44970 is a reply to message #44967] Fri, 16 July 2004 15:55 Go to previous message
I stock 1" long #8 black wood screws, so let me know if you need 'em and I'll mail you out some.
For sealing purposes, there are a number of different gasket materials you can use. If the joint is two flat surfaces, a cardboard gasket works well and it is easy to install and remove. Silicon and caulking materials form a good seal, but they often stain wood and are harder to clean and remove.
Previous Topic: pialign.exe and XP
Next Topic: Theater 4pi Plans
Current Time: Sat Oct 17 06:15:13 CDT 2026
