Home » Sponsored » Pi Speakers » Curious about Chip Amps?
Re: Curious about Chip Amps? [message #44829 is a reply to message #44814] Sat, 26 June 2004 22:39 Go to previous messageGo to previous message
wasteh202 is currently offline  wasteh202
Garland
Thanks for you post about the chip amp. I bought a Griffer Powerwave amp a couple months back. I also was very impressed with it. I paid much more than you did for the Target... I think about $100.00 total. My digital amp has only 10wpc.
My finding were simular to yours. I was extremetly pleased with the bass from a amp that had only 10wpc. VERY GOOD BASS ! Mine is stock but these things are being modded.
I hooked the powerwave to my computer and my 2Pi towers to the Powerwave.. WOW ! Nearfield listening with the Powerwave and the Towers was quite reveling ! Also as you said... the highs were rolled off. Not a problem for me as my Towers are a bit too bright for me.
My Powerwave worked best with the computer. For some reason when I conected the digital amp to my preamp and source... I got a slight hum through my speaker. Not a bad one... but noticable enough to bother me in between tracks.
I believe it is only a matter of time and the digital amp will pretty much replace tube and SS amps. Smaller, lighter and cheaper.... and sound good too... how can you loose ? Mine even has a nice pretty blue light that glows for the tube lovers out there that want something pretty to look at while listening to there favorite artist.
Previous Topic: Displacement by Horn and Driver?
Next Topic: Pi 8
Current Time: Sun Oct 25 18:48:42 CDT 2026
