Home » Sponsored » Pi Speakers » Here we go again. Merits of 2" compression vs cone midrange
Re: Here we go again. Merits of 2" compression vs cone midrange [message #44687 is a reply to message #44686] Mon, 31 May 2004 16:30 Go to previous messageGo to previous message
I think my personal preference would lean towards a cone midrange... Lower frequency cut off, more power handling... Also gives the option of not having to use a horn, and using different cone materials besides the usual titanium. I find the midrange on compression drivers to be less clean and present then that of cones. Also, a cone mid will also allow you to cross over much lower. A big disadvantage with crossing over a compression driver in the 800-1,600 Hz range, is that range is a critical vocal region, and putting a crossover point in that region is not ideal. A cone driver can cover the entire critical range on its own, whereas a CD will need augmentation.
Just some thoughts.
Adam
Previous Topic: studio 2 pi
Next Topic: Two Pi Plans
Current Time: Sun Nov 01 13:47:03 CST 2026
