Home » Sponsored » Pi Speakers » NooBee Question
NooBee Question [message #44676] Thu, 27 May 2004 15:01 Go to previous message
Dean Kukral is currently offline  Dean Kukral
I am planning on building a Pi-seven using a JBL woofer and BMS 4592 compression driver and horn.
So if I buy (or design, but I would prefer to buy) an 800Hz crossover, then I assume the two should work together, but how does one balance the two drivers sound-level wise? (I assume that this is what is meant by using compensation.) Is it simply a matter of experimentation by adding resistance in series with the 4592? If so, do I just order some resistors from Parts Express and then try them? If so, what wattage should they be, and what variation of ohmage? I have quite a few large ceramic resistors left over from my slot-car days; I suspect that I could experiment with these.
I know that this has already been done with the kits that Wayne sells, but how does this get done from scratch?
(My original plans were different or I would just buy a kit.)
Previous Topic: studio 2 non tower
Next Topic: What is the best way to "flush mount" speaker drivers?
Current Time: Sat Nov 07 00:55:23 CST 2026
