That's close enough. You won't notice any change at all. If you want an easy test, put a 1uF capacitor in parallel across the 8uF and it will form 9uF. Give it a listen and see if you can hear the difference. You'll hear a little click when you switch the cap in and out of circuit, or maybe some connection noise if you do it with aligator clips or something. But once the cap is in or out, the difference is teeny-tiny.
