Home » Sponsored » Pi Speakers » 8pi cabinet questions
8pi cabinet questions [message #44598] Mon, 10 May 2004 08:13 Go to previous message
Duncan McBride is currently offline  Duncan McBride
From the 8pi sketch it looks like the port (or ports) can be located at the bottom of the front panel, which would look really cool. If I were to use the three oval ports you put in the sketch, how big should they be? Would they be like the 2pi tower and just be the width of the cabinet side, or will I need extensions? Also, should I install fiberglass for damping in the cabinet as with other bass reflex enclosures? Foam insulation around the back of the horn?
Many thanks,
Duncan
Previous Topic: studio 2 tower
Next Topic: Pi vs Super Sound Boomers
Current Time: Fri Nov 06 02:03:07 CST 2026
