Home » Sponsored » Pi Speakers » Holy Trigonometry!
Re: Great link - and there's always Dr. Math [message #44592 is a reply to message #44588] Sat, 08 May 2004 21:07 Go to previous message
Duncan McBride is currently offline  Duncan McBride
Hey, thanks. They look better in the pictures than in person, but I'm looking forward to hearing them. If I hadn't been so impatient, I'd be ordering the kits now, but it's been interesting so far.
You're right, the angle of the sides would vary on the tractrix. On a straight sided conical the angle should be the same all the way. I was able to cut the verticals along each edge and when I propped up the bottom piece to a reasonable angle I could just set the sides in place and put the top on, and it would sit there like a house of cards. I looked all around and all the edges were flush. Neat. I glued and screwed it together and the next day the tops and bottoms had warped inward about 1/4" at the center. I had to build a little brace with a threaded rod to push them out when I glued the horn to the cabinet pieces. Those kits are sounding better all the time, but I'm learning.
Previous Topic: 7 PI profess'l series w / 10 in. mid plans
Next Topic: Midhorn/8pi
Current Time: Sun Nov 29 15:45:16 CST 2026
