Home » Sponsored » Pi Speakers » midhorn kit? and some design choices
midhorn kit? and some design choices [message #44536] Sat, 01 May 2004 11:57 Go to previous message
Hi Wayne and group,
Just wondering if the flat pack kits will be offered in a high grade birch ply? Also the response graphs for the mid horn, were those with a Delta 10? Have you looked at response of the JBL 2012H on the horn? It is my best guess from looking at the manufacturer published graphs that the 2012H may have even flatter response on the horn (aside from the other obvious reasons for such a driver choice)
I am thinking of the JBL equipped midhorn and Peavey CH-3 with BMS 4540 (It looks like a good match to CH-3 and it even has screw mount, HA!) For the mid/high cabinet. There are so many sexy HF horn choices, but I have used a lot of horns at this point and I can't really beat the CH-3.
Since I will have no need to push the woofer past the hundreds what do you think of the 2242H? I want shocking impact, solid bottom end and clarity that will compel people to ask "what the heck is that?". I am not set on any one thing. I want flux stabilized, Low fs, Large radiating area, high sensitivity and "I can't believe that bass!" sound quality. That pretty much leaves the JBL and the Magnum. Comments?
Thanks,
Thomas
Previous Topic: 8pi tube electronic xover
Next Topic: Help a single driver noob
Current Time: Sat Nov 07 02:44:46 CST 2026
