Home » Sponsored » Pi Speakers » Playing with new midrange horn.
Re: Playing with new midrange horn. [message #44436 is a reply to message #44434] Wed, 21 April 2004 23:17 Go to previous messageGo to previous message
Great to hear from you Grant. Hey, check out Adrian's horn. He's already done the homework for a horn that mounts an Alpha 6, so I expect your PHL 1660 will work just fine with it.
To match sensitivity levels, you can pad the horn with a 4 ohm resistor in series and an 8 ohm resistor in shunt. This brings the sensitivity down but dynamic range is still increased by horn loading. And drive requirements are less, so distortion is reduced too.
For a spacer, you can sure use the spare MDF you're talking about, but that requires you to cut a ring. Another way to do it is to use an extra gasket as a spacer. They don't cost much and most recone shops have them.
Previous Topic: studio 2 towers
Next Topic: Studio PI Plans, Calling Wayne
Current Time: Sun Nov 01 06:03:50 CST 2026
