Home » Sponsored » Pi Speakers » 8 Pi with Alpha 10
8 Pi with Alpha 10 [message #44421] Mon, 19 April 2004 14:09 Go to previous message
Hi Wayne,
I'm fascinated with your concept, but I was unclear
on part of it. Are you hoping to use a single Alpha 10
horn loaded for the mids and BR for the bass? In this
case would the low frequency sound come primarily from
the midhorn throat without augmentation because it's
below the horn cutoff, or would you expect as much or more
to come from the rectangular ports at the bottom. In some
circumstances, I suppose the horn throat could take on
BR port characteristics, though I imagine this would be
to the detriment of the mids.
If you are using a single Alpha 10 with different loadings,
how do you balance the lows with the horn-auagmented mids?
I'm eager to learn about and build this one.
Thanks,
Skip
Previous Topic: Which Pi model is most like the Altec A7?
Next Topic: New Addition to Family
Current Time: Sun Nov 01 02:54:07 CST 2026
