Home » Sponsored » Pi Speakers » PI studio series 2 tower
Re: PI studio series 2 tower [message #44400 is a reply to message #44392] Thu, 15 April 2004 07:08 Go to previous messageGo to previous message
Tom,
I built the 2PI Towers as my first speaker project and had very little problems with it. The only trouble I had during the build was moving it on and off the workbench. I used 1" MDF and over-braced, so it became pretty heavy.
I did have all the panels cut to spec at the big-box store, so that helped a lot. When I got home, it was just a matter of piecing them together. Most big-box stores that I know of will cut for you if you give them a cutting diagram.
Gar.
Previous Topic: "You want those JBL's to go?
Next Topic: Cool input terminals, and cheap!
Current Time: Fri Nov 06 01:52:42 CST 2026
