Home » Sponsored » Pi Speakers » Midrange Horn
Re: Dimensions [message #44386 is a reply to message #44381] Tue, 13 April 2004 16:21 Go to previous messageGo to previous message
Yes, those are inside dimensions. The H295 horn needs EQ, so many of the padding issues would still remain. You could use passive components as I have, or remove them and go with active instead. But either way, there is going to need to be some HF compensation or a super-tweeter and the woofer system must be considered too. There's lots of good options and ways to implement this.
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Mon Oct 19 14:07:46 CDT 2026
