Home » Sponsored » Pi Speakers » Basshorn plans please - Wayne
Re: Basshorn plans please - Wayne [message #44253 is a reply to message #44252] Mon, 29 March 2004 03:21 Go to previous messageGo to previous message
The ten π horn is about 27ft3. The folded basshorn section was originally designed to cover 40Hz to 400Hz, although I found that you can push them much higher than this because the folds tend to act as reflectors that direct higher frequencies out through the mouth. The basic layout is shown on the last couple of pages in the PiAlign document.
The π cornerhorn covers the entire audio band. It uses the expansion of a room from the apex of the corner as a large horn, and this expansion forms the horn in toto. The chamber between the driver and the corner forms the horn's front chamber and the speaker box forms the horn's rear chamber. You can set compression ratio with a compression plate/ring too. And you can vent the rear chamber to extend bass response. It's a very simple and effective configuration. See the posts called "Cornerhorns" and "Room corner charatcteristics" for more discussions along these lines.
Previous Topic: pseudo 1 Pi corner horns
Next Topic: Compensation Network connection
Current Time: Sun Nov 29 19:21:42 CST 2026
