Home » Sponsored » Pi Speakers » Subwoofer project
Re: Subwoofer project [message #44246 is a reply to message #44242] Fri, 26 March 2004 07:03 Go to previous messageGo to previous message
The device is a subwoofer that can be used in a 2ft3 to 6ft3 ported cabinet or in a basshorn such as the LABhorn. This subwoofer is a high-fidelity option to the LAB12. It is being designed by Eminence who makes the LAB12, and it will be built by Eminence. It is essentially a better quality high-fidelity version of the LAB12 woofer.
The requirements for the device are that it have the same electro-mechanical properties as the LAB12 but at least -10dB less distortion through the use of a flux stabilization ring. Since power capacity is the same, you can use it for pro sound. You can also use it for home or car applications. It's just a higher quality, higher fidelity woofer than the LAB12, and the price is not going to be much more at all.
Previous Topic: B12 Subwoofer Project Update
Next Topic: Hi Wayne
Current Time: Mon Oct 19 12:52:59 CDT 2026
