Home » Sponsored » Pi Speakers » Speaker Problem - Wiring???
Re: Speaker Problem - Wiring??? [message #44191 is a reply to message #44189] Fri, 19 March 2004 00:00 Go to previous message
It does sound like you're cross-wired. But to make sure you aren't confused, I'd try to grab a wiring diagram to be sure. Trace all the wires to make sure you know what speaker wire is what, and then start from scratch using your wiring diagram.
Before you start running wires, you might connect each speaker one-by-one to a known good output to verify that each speaker is functional. Might check each amplifier output the same way. Then you'll know that everything is working, and you can focus on making sure you connect everything up right and don't get your wires crossed.
Previous Topic: PiAlign Enclosure Type?
Next Topic: I have seen the LIGHT!!!
Current Time: Fri Oct 23 17:35:52 CDT 2026
