Home » Sponsored » Pi Speakers » PiAlign Enclosure Type?
Re: PiAlign Enclosure Type? [message #44179 is a reply to message #44177] Wed, 17 March 2004 22:48 Go to previous message
PiAlign makes a critically damped alignment for speakers having Qts of 0.38. It is really more like a range of drivers between 0.25 and 0.5 that you can expect this sort of response. As woofer Qts rises above 0.5 or so, it gradually allows the system to become underdamped. And as woofer Qts falls below 0.25, the system tends toward being overdamped.
What I like best is that I can count on the system to be tuned right and well-damped in a box of reasonable size. The high Qts stuff is going to be underdamped unless the box is huge, and PiAlign manages to give a great compromise of size to damping. When we get into the 0.25 to 0.5 Qts range, the boxes are all of moderate size and the system is nearly critically damped, flat as can be. And when a woofer is used having very low Qts under 0.2, the system is overdamped and makes a response curve like a sealed box.
Previous Topic: MAG12 Subwoofer
Next Topic: Speaker Problem - Wiring???
Current Time: Sun Nov 01 21:04:59 CST 2026
