Home » Sponsored » Pi Speakers » professional seven pi
professional seven pi [message #44074] Fri, 27 February 2004 18:57 Go to previous message
more is currently offline  more
Hey gang, I started cutting wood yesterday and need to get a few things straight before I continue.
One drawing in the set of 7pi professional plans seems to show the total height of the corner horn box at 34.25" but the picture of the baffle seems to indicate the baffle alone is 34.25", which would mean the total height is actually 35.75"? Or does the baffle need to be reduced to 32.75"? Or doesn't it really matter anyways - ? I've already cut the front,rear and sides to 34.25 but I can shorten them if necessary of course. I also will not be mounting my HF horn/driver inside the cabinet - do I need to adjust the volume downwards? I was thinking of just tossing in some smallish cleats and braces to maybe take up some of the "extra" space.
I would rather cut a circular port hole in the baffle and use a port tube centered underneath the 2226 if possible. What width/length circular tube should I use?
Previous Topic: One Pi plans
Next Topic: BETA 12LTA in a PiAlign enclosure
Current Time: Sat Oct 24 13:42:10 CDT 2026
