Home » Sponsored » Pi Speakers » are Beyma Pro drivers any good for Hi-Fi? Comparable to JBL's?
LX-60 and G40 [message #44065 is a reply to message #44058] Fri, 27 February 2004 06:59 Go to previous messageGo to previous message
As I said before, the LX-60 is the best choice for low frequency subwoofer duty.
LX-60 has:
*9mm linear excursion vs 7mm of the G40, hence greater SPL capability
*LX-60 works in SBB4 alignment because of lower Fs and lower Qts, it's better damped with no sharp knees in the group delay (better transient response)
G40 has:
*0.5db less power compression at 700W
*Dual Spiders and what Beyma calls an improved motor structure
Both drivers will work though, but I'd prefer the LX-60. In a pro sound application the more rugged G40 with dual spiders will withstand high volume levels for longer, but for a home application the LX-60 has more benefits. I'd expect it's probably a little cheaper too, if the G40 is a new model.
Overhang and top plate thickness of both models are actually the same though according to Beyma, so the quoted 9mm xmax of the LX-60 to the G40's quoted 7mm xmax should possibly not be used as a comparison; they should have the same linear excursion. The better transient response capability is what really makes me choose the LX-60. To me, having tight transient response is very important.
Previous Topic: crossover
Next Topic: Passive Line Level Compensation Network?
Current Time: Mon Sep 21 13:51:16 CDT 2026
