Home » Sponsored » Pi Speakers » 2pi towers
Re: 2pi towers [message #43895 is a reply to message #43892] Tue, 10 February 2004 08:27 Go to previous messageGo to previous message
Wayne can correct me if I'm wrong, I don't think there's such thing as over-bracing. There are however, a few things to keep in mind:
- Internal volume need to be maintained. If you're going to over do it, cabinent dimensions need to be adjusted.
- Air movements should not be restricted. Brace all you want, but make sure air can still move freely. Don't create subcompartments inside your cabinet connected by small "ports".
- Try not to create "symetrical section" with window bracing in your cabinet. Something about standing waves when compartments have dimensions that are multiples of each other.
- You will have to move speakers around. Too late for me. The combination of 1" MDF and extra bracing requires two people to move the speakers around.
In the end, I think I did over do it. But it didn't take that much extra work during the build. The only draw back now is that they're a pain to move.
Gar.
Previous Topic: 4 pi theater plans, pleeze...
Next Topic: HF horn dimentions and low end cut-off
Current Time: Thu Nov 05 14:53:19 CST 2026
