Home » Sponsored » Pi Speakers » taming the piezoelectric
Re: taming the piezoelectric [message #43888 is a reply to message #43887] Mon, 09 February 2004 11:10 Go to previous messageGo to previous message
jlharden is currently offline  jlharden
Hi waste,
I had good results with damping the back side of the piezo with mortite. I don't know if this will do what you are wanting though. There was also talk of disassembling the tweeter and using dammar varnish on the diaphram. If I recall correctly, this was from the single driver website where the Motorola piezo's get a decent amount of use. I haven't tried this and probably won't. The biggest difference in sound came when I switched from a pretty good quality solid state amp to a better push pull pentode amp. Better bass, midrange, and highs. Really transformed this speaker. I think the sound could be characterized as a warm, full bodied sound with hifi characteristics, yet possesing drive and dynamics not typically found in "hifi" speakers. In a nutshell: great sound with plenty of balls!
Good luck with your speakers and keep us posted. Jerrod
Previous Topic: 2pi tower pics
Next Topic: Recommendation on Horn Flare for 4 Pi
Current Time: Thu Nov 19 21:52:28 CST 2026
