Home » Sponsored » Pi Speakers » PiAlign program
Re: PiAlign program [message #43780 is a reply to message #43779] Tue, 27 January 2004 08:02 Go to previous messageGo to previous message
David Morrison is currently offline  David Morrison
but when I model a small horn there is no response in the bass region can one of your horns with desired cutoff be used for a box. Then adjust the tuning to get the responce you want.
I know both programs and have been using Boxplot for awhile but horn responce is still new to me. But i still believe in trial and error for a box design but it helps to have a theory of how it will change then have a theory on why you got the change you did. for instance I built a fourth order bandpass that modeled good the the port was to small.
Previous Topic: One PI Port Size
Next Topic: Found a new source for driver parameters
Current Time: Fri Nov 06 00:36:45 CST 2026
