Home » Sponsored » Pi Speakers » What are compensation networks?
Re: What are compensation networks? [message #43772 is a reply to message #43767] Mon, 26 January 2004 19:52 Go to previous messageGo to previous message
Compensation networks are electronic EQ and/or impedance compensation devices. An example is a Zobel circuit, which is used to remove a response peak that would otherwise result from the interaction of capacitance in a passive crossover and the speaker's voice coil. Another example is horn compensation.
See the response curve of the tweeter circuit of a π Speaker using a compression horn:
Response curve for HF circuit of π Crossover
For more information, see the links on the post called "A few useful documents."
Previous Topic: same speakers
Next Topic: Constrained spatial loading
Current Time: Wed Oct 21 13:28:20 CDT 2026
