Home » Sponsored » Pi Speakers » PiAlign program
Re: PiAlign program [message #43755 is a reply to message #43751] Thu, 22 January 2004 16:45 Go to previous messageGo to previous message
I wrote PiAlign and I defined the term Qe used within it. I mis-spoke because Qe is actually a ratio of port length to area, not cabinet volume. But the point is that it is an indicator of port restriction to airflow.
PiAlign was designed to iterate and find solutions to the forumulas that express Pi Alignment for a loudspeaker cabinet. To perform T/S analysis of a Pi aligned cabinet or others, I suggest using something like Carlson's BoxPlot. That will show you the response curve of a speaker using whatever alignment parameters you enter into the program.
Previous Topic: One PI Port Size
Next Topic: Found a new source for driver parameters
Current Time: Fri Nov 06 00:37:03 CST 2026
